Good day all.....My '96 LS400's outside power mirror has become discolor....anyone know why? How much would it cost to replace it? Where can I purchase the part and how hard is it to do it? Thanks for all your replies.....
It's behind the mirror...I think. I believe it has something to do with the Auto-dimming inside of the mirror.....It look like when you push down on an LCD screen, the chemical inside of the LCD get all over under the glass....
you can change just the mirror. i'm not sure how much itsgonna cost you, for the part, but the labor is gonna be cheap. if you want i will provide you with diagrams
:) VMP, Please provide diagrams....thanks for your assistance....I will call the local dealer and see how much it will cost for the mirror.....
IF NECESSARY, DISCONNECT MIRROR
(a) Insert the shop rag between the mirror and the mirror body to wrap up the mirror in the shop rag.
B) Pull up the lower side of the shop rag to disconnect the mirror joint.
c) Pull up the mirror and disconnect it.
d) Disconnect the connector.
CONNECT MIRROR
(a) Connect the claws (A) and set the mirror to the mirror body.
(B) Push the mirror to connect the claws (B) and connect it.
Damn.....my local dealer want $349.00 for just the mirror.....I am going to look for a junk yard now....
check ebay as well and call those guys
800-765-7100 or www.taperecicliing.com
better call em up. big junk yard
Yep, pretty common actually. My dad's LS came like that from the factory.
