2006 Oil Drain Plug Location
tedfmar@us.ibm.com
We have a 2006 RX330 and I would like to drain the oil and refresh between dealer visits. I believe that the plastic guard below must be removed to get to the oil filter but I am hoping that this is not the case to just drain the oil and replace. Any advise on where the plug is would be appreciated. Thanks.
Someone posted a step by step DIY tutorial on oil change some time ago, I couldn't find it at the moment but I'm sure someone will post a link to it shortly. Or search yourself, you might have better luck than I.
Search oil change, its all there with pictures
Booyah:
Thanks for the quick reply but I am not getting any hits when I search on "oil change". Am I doing something wrong by just plugging in those two words into the search bar? Thanks again.
Try this ...
http://us.lexusownersclub.com/forums/index...9&hl=oil+change
Oh sorry, someone beat me to it.
When doing searches after you plug in the search stuff--if comming off the 33o forum it will automatically be selected for ya....but the big thing is the one box off to the middle right that says "search post from" ANY DATE--select that to say Today and click the dot to say Older. So now you are searching from today till wayyyy back when
