maniek_LS Posted February 18, 2006 Share Posted February 18, 2006 Hi, my LPG conversion have few options to get signal to control LPG ECU. Now LPG ECU is connected to igniter, but ECU interprets engine speed incorrectly (doubled). One (best, recommended) way is to get signal from tachometer. Do you know where can I connect (except instrument panel removal) to receive signal which reaches tachometer. Best will be TDCL, or any connector under hood... Thank you. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted February 18, 2006 Share Posted February 18, 2006 From a coil or injector on the engine. Quote Link to comment Share on other sites More sharing options...
maniek_LS Posted February 18, 2006 Author Share Posted February 18, 2006 SKperformance thanks, but it is not working :-( I wrote that current solution is LPG ECU connected to coil - I have readings doubled :-( I need to have one to one. On tachometer I have 700RPM my LPG ECU reads 1400 :-(.. Quote Link to comment Share on other sites More sharing options...
RFeldes Posted February 19, 2006 Share Posted February 19, 2006 Try these guys............http://www.go-lpg.co.uk/ Quote Link to comment Share on other sites More sharing options...
