Four-wheel Alignment
How often is a four-wheel alignment supposed to be done? I've heard anywhere from three to five oil changes to only whenever you do suspension work.
I drive mostly highway miles from NYC to Norwalk, CT (by Stamford) so the roads aren't great. Does that affect the mileage interval of when an alignment should be done?
HI
if the road youre driving on is smooth then check it every 6000 miles if you hit curbs when parallel parking or going over bumpy potholes or bumps on the road driving fast you should check it every 3000 to 4000 miles...one way to check is turn wheel all the way to the left or to the right check inside of tire or outside of tire if it is wearing and getting bald check the alignment
