faiello Posted February 17, 2006 Share Posted February 17, 2006 I just purchased a set of 2006 17" GS 10 spoke chrome rims through ebay from OEMRIMS for my 2004 GS300. I was wondering what size tires I should get 225/50-17 standard size for 2006 or 235/45-17 standard size for 2004. The original 16" tires on my car were 225/55-16. 225/55-16=25.74 outside dia. 80.82 circ. 225/50-17=25.86 outside dia. 81.20 circ. 235/45-17=25.33 outside dia. 79.52 circ. The math says go with the 225/50-17. Does this make sense? http://cgi.ebay.com/ebaymotors/LEXU...emZ80 28960624 __________________ 04 GS300 Blk/Blk/Nav/ML/HID/Rear Spoiler Phython Remote Starter/35% Tint /Clear Bra 85 MB 380SL Diamond Blue/Navy Quote Link to comment Share on other sites More sharing options...
SGISL3V0E0R06 Posted February 17, 2006 Share Posted February 17, 2006 hi i have 06 gs3 with 2255017 on there and working at discount tires for 15 years this is a good size for a good ride if you wanna go with a wider tire and a common size tire is 2354517 thanks Quote Link to comment Share on other sites More sharing options...
faiello Posted February 17, 2006 Author Share Posted February 17, 2006 hi i have 06 gs3 with 2255017 on there and working at discount tires for 15 years this is a good size for a good ride if you wanna go with a wider tire and a common size tire is 2354517 thanks Thank you for the quick response. I will probably go with the 235/45-17 because it is a more common size and my tire dealer will need to order the 225/50-17's. How much will this effect my speedometer and odometer? Quote Link to comment Share on other sites More sharing options...
SGISL3V0E0R06 Posted February 17, 2006 Share Posted February 17, 2006 hi i have 06 gs3 with 2255017 on there and working at discount tires for 15 years this is a good size for a good ride if you wanna go with a wider tire and a common size tire is 2354517 thanks Thank you for the quick response. I will probably go with the 235/45-17 because it is a more common size and my tire dealer will need to order the 225/50-17's. How much will this effect my speedometer and odometer? hi this will not affect speedometer reading at all and the best price is at either discount tire co.or tirerack.com depends where you live thanks Quote Link to comment Share on other sites More sharing options...
p3style Posted February 22, 2006 Share Posted February 22, 2006 Search and you will find =) http://www.net-comber.com/tirecalc.html hi i have 06 gs3 with 2255017 on there and working at discount tires for 15 years this is a good size for a good ride if you wanna go with a wider tire and a common size tire is 2354517 thanks Thank you for the quick response. I will probably go with the 235/45-17 because it is a more common size and my tire dealer will need to order the 225/50-17's. How much will this effect my speedometer and odometer? hi this will not affect speedometer reading at all and the best price is at either discount tire co.or tirerack.com depends where you live thanks Quote Link to comment Share on other sites More sharing options...
