godfather18 Posted February 17, 2006 Posted February 17, 2006 I just replaced the 8 bulbs behind the cluster on my friends 1994 ES300 and now the temp gauge goes strate up to hot and wont go down what do you guys think I did wrong or should do.
godfather18 Posted February 17, 2006 Author Posted February 17, 2006 Cant be I replaced them or my 1992 ES and that didnt happen, I didnt touch anything just replace the bulbs and put the cluster back together thats it.
dcfish Posted February 17, 2006 Posted February 17, 2006 Cant be I replaced them or my 1992 ES and that didnt happen, I didnt touch anything just replace the bulbs and put the cluster back together thats it. You had to take the circuit board off of the main board right ? It sounds like something got jolted or loosened, Maybe the contacts. Sometimes those boards get brittle.
godfather18 Posted February 17, 2006 Author Posted February 17, 2006 Yes I did, what do you think I should do? Do you have AIM
Toysrme Posted February 17, 2006 Posted February 17, 2006 Checking the resistance on the coolant sensor will show it's good. I'd take it back apart & start checking any wires, or traces for shorts.
dcfish Posted February 17, 2006 Posted February 17, 2006 Yes I did, what do you think I should do? Do you have AIM Well, I can tell you that the screws and the surfaces of the boards are part of the continuity and resistance of the cluster. It has to go back together exactly as it was. Maybe the guage is shot. You can change just the guage, It slides out quite easily.
godfather18 Posted February 17, 2006 Author Posted February 17, 2006 Those needles each have a ground on the second board where they stick, I'll check that out and make sure that its touching the contacts I put the screws back together, but the gauge was working fine before I changed the bulbs
dcfish Posted February 17, 2006 Posted February 17, 2006 Those needles each have a ground on the second board where they stick, I'll check that out and make sure that its touching the contacts Very good, Double check everything and clean any contacts that are exposed while uninstalling including all three connections on the back of the cluster.
godfather18 Posted February 17, 2006 Author Posted February 17, 2006 The screws on the sides are very thin towards the end and there are six of them on each side. They look the same to me. But I didnt put the exact screw that was exactly in the hole cause they look exactly the same. Should that matter? DO you have Instant Messenger so I can talk to you direct Do you work for Lexus, cause u sound like you know what ur talking about?
dcfish Posted February 17, 2006 Posted February 17, 2006 The screws on the sides are very thin towards the end and there are six of them on each side. They look the same to me. But I didnt put the exact screw that was exactly in the hole cause they look exactly the same. Should that matter? DO you have Instant Messenger so I can talk to you direct Do you work for Lexus, cause u sound like you know what ur talking about? No AIM. The reason why we discuss this on these boards is to enlighten others ( and ourselves ). It would be defeating the purpose of these forums if this were private.
godfather18 Posted February 17, 2006 Author Posted February 17, 2006 What do you think in your opinion is the problem with this temp needle?
dcfish Posted February 17, 2006 Posted February 17, 2006 What do you think in your opinion is the problem with this temp needle? Connection/contacts/cleanliness. Do not discount the sensor.
godfather18 Posted February 18, 2006 Author Posted February 18, 2006 What do you think in your opinion is the problem with this temp needle? Connection/contacts/cleanliness. Do not discount the sensor. Figured it out, one of the screws was not all the way down and caused the temp gauge to not have the right current to it and now its working perfectly fine
dcfish Posted February 18, 2006 Posted February 18, 2006 What do you think in your opinion is the problem with this temp needle? Connection/contacts/cleanliness. Do not discount the sensor. Figured it out, one of the screws was not all the way down and caused the temp gauge to not have the right current to it and now its working perfectly fine I thought so, Glad you found the prob. I take cashiers check and money orders, Thanx. ;)
