Where is the fuel line located under the hood of the second generation GS400? Is it visible without removing the plastic cover? post-18984-1139377584_thumb.jpg
I see it. driver's side. metal tuble with a flare fitting to a rubber hose. 14mm and 19mm connection. between the oil cap and master cylinder.
i would say if you can't find the fuel line on your own you have no business messing with it :P
agreed
