wsburns11 Posted January 25, 2006 Share Posted January 25, 2006 Have a 2003 gx. was one of the first to own one. car has been good to me. now 40k miles. About a year ago I started getting the "check air conditioner" message---and, in fact, when the message is on, there is no cold air. the problem comes and goes. brought it to two lexus service shops. unfortunately, when i brought the car in the message wasnt on and both times service told me they couldnt find a problem.. It's now winter in new jersey and the check message is coming on again. has anyone else had this problem? Quote Link to comment Share on other sites More sharing options...
mryellow Posted January 25, 2006 Share Posted January 25, 2006 Have a 2003 gx. was one of the first to own one. car has been good to me. now 40k miles. About a year ago I started getting the "check air conditioner" message---and, in fact, when the message is on, there is no cold air. the problem comes and goes. brought it to two lexus service shops. unfortunately, when i brought the car in the message wasnt on and both times service told me they couldnt find a problem.. It's now winter in new jersey and the check message is coming on again. has anyone else had this problem? have Lexus dealer check service bulletin EL009-05 refering to a/c magnetic clutch relay failure/sticking--should be covered under warranty 4yr/50k miles--applied to ES (02-04) and GX (03-04)--usually causes A/c light to flash indicating A/C compressor trying to come on but cant because of faulty relay--an updated relay is avail to fix condition---I am a Lexus master tech here in ATL and you can email me if you have any further quest.--hope this helps Quote Link to comment Share on other sites More sharing options...
wsburns11 Posted January 25, 2006 Author Share Posted January 25, 2006 Have a 2003 gx. was one of the first to own one. car has been good to me. now 40k miles. About a year ago I started getting the "check air conditioner" message---and, in fact, when the message is on, there is no cold air. the problem comes and goes. brought it to two lexus service shops. unfortunately, when i brought the car in the message wasnt on and both times service told me they couldnt find a problem.. It's now winter in new jersey and the check message is coming on again. has anyone else had this problem? have Lexus dealer check service bulletin EL009-05 refering to a/c magnetic clutch relay failure/sticking--should be covered under warranty 4yr/50k miles--applied to ES (02-04) and GX (03-04)--usually causes A/c light to flash indicating A/C compressor trying to come on but cant because of faulty relay--an updated relay is avail to fix condition---I am a Lexus master tech here in ATL and you can email me if you have any further quest.--hope this helps Thanks so much. I have a nav system and the warning is displayed "CHECK AIR CONDITIONER". There is no "A/C Light" in my car. Are still talking about the same problem. Is this the way you wanted me to reach you? if not, what is your email address? thanks again. Quote Link to comment Share on other sites More sharing options...
