LexKid630 Posted January 24, 2006 Share Posted January 24, 2006 A few days ago i changed the rear turn signal bulbs (03 rx300) with brighter bulbs. Today (~40 deg. F), i noticed that there was condensation on the inside of the plastic housing ONLY in the units that i had JUST had the bulbs changed (meaning only the outer units w/ directionals, not the ones attached to the tailgate). I just removed the lamps tonight, and blow-dried the moisture out. Haven't put them back in, don't know what to do :( I have owned rx300's before and never noticed this. Does it have anything to do with me changing the bulbs? It was a bright sunny day in the 40's when i changed them. I only had the bulbs out for maybe 3 minutes tops. Will this moisture come back? Thanks for your help! Quote Link to comment Share on other sites More sharing options...
mehullica Posted January 26, 2006 Share Posted January 26, 2006 Did the rubber seals for the bulb sockets fall off? Quote Link to comment Share on other sites More sharing options...
LexKid630 Posted January 26, 2006 Author Share Posted January 26, 2006 Did the rubber seals for the bulb sockets fall off? Nope, they're in perfect condition. I did notice water behind the unit's after i took them out (on the car itself behind the tail lights). I dried it and put the units back carefully and snug. Haven't noticed any moisture in the lamps snice then, so maybe it was just a one time thing? I'm thinking that it was caused by all the moisture in my garage the night before? There was snow on the car when i put it in the garage and in the morning there was a LOT of water all over the floor etc... maybe a bit of moisture got in the tail lamps and had a hard time leaving with all the moisture in the air. I don't know; all i do know is that the moisture is gone! Thanks! Quote Link to comment Share on other sites More sharing options...
