My GS300 has had this noise problem almost from new it is coming to the stage where it is affecting my driving and health. A serious problem I think you will agree.
The car is fitted with 17 inch rims with low profile tyres.
The noise is heard at different speeds and increasing in intensity as speed increases. Road noise accepted as the explanation. The Amount of road noise in vehicle is not accepted.
A high pitch noise is heard at various speeds. Sounds like a jet engine. The only time I want to hear this type of noise is when I am going on holidays to a warmer climate.
The third noise I have in my luxury car is a heavy breaking sound when the breaks are applied.
My Lexus dealer replaced the break discs and pads in an attempt to resolve the problem. This attempt was a failure
My Lexus dealer replaced my 17 inch rims with 16 inch rims fitted with standard tyres in an attempt to reduce road noise. This attempt was a failure
I replaced the tyres on my 17 inch rims with a different make and compound tyre. This also failed to reduce the amount of road noise heard in the vehicle.
The problem I have now is that Lexus is stating that the noise I have in my luxury car is normal. ??????????????? I think not
Any comments
sorry guys an error in my message
the message 16 inch rims fittes read successful of course it should have read failure
sorry
My Lexus dealer replaced my 17 inch rims with 16 inch rims fitted with standard tyres in an attempt to reduce road noise. This attempt was successful
Any comments
What type/mfg. are the 17" wheels? What mfg./size tires are the 17" Were the brake pad shims also replaced? Explain in more detail what you mean by "heavy breaking sound"
You could have either keep these 16" rims and quiet tires or put these quiet tires on your 17" rims. Why didn't you pursue either of those options?
could be your rear end(diff). my 01 GS430 had the rear end replaced via warranty at 23k miles because it made a humming, bass type sound when you let off the gas around 60mph.
The 16s do ride more quietly then the 17s. Tire brands also makes a difference. Lastly, though, the GS is not the quietest in the Lexus line. Noise is very dependent on the individual. What you deem loud may be normal to me or maybe not. It is hard to tell.
Good luck in finding the root of the problem.
Appreciate the help
I bought this Lexus in September 2004 and have had a number of small problems. Including scratches on the driver and passengers side windows. Both windows Replaced by my Lexus dealer. Rattles in the dash. Rectified by my Lexus dealer. The noises in my Lexus appear to be falling on deaf ears by my Lexus dealer and more disturbing by the national distributor. I really need good advice on this problem.
The Tyres on the vehicle now are
Dunlop SP Sport FM901
235/45ZR17 93W
235/45ZR17 93W
Any other GS owners with dif problems
would like to hear your problems??
