Turn Signals
do they flash when you use the "hazards"?
If they flash with the hazards then the problem may be in the signal lever....maybe a switch problem.
If they do not flash with the hazards then it is most likely in the wiring closer to the lights.....maybe a relay problem.
start there and let us know what you find out.
steviej
