The turn signals in my car will not work. Nothing blinks on the dash and the lights espcially do not blink. All the fusers are fine, what else could be the problem?
do they flash when you use the "hazards"?
If they flash with the hazards then the problem may be in the signal lever....maybe a switch problem.
If they do not flash with the hazards then it is most likely in the wiring closer to the lights.....maybe a relay problem.
start there and let us know what you find out.
steviej
