Timing Belt And Associated Parts
sapper_daddy
I still need to download a service manual. I am trying to get together all the parts to change my timing belt and some other things. On the lexls site it say's timing belt idler no1 and 2 all i can find is one make of bearing for that. Can anyone give me the part no. for both of them. Is it the same part no? How hard is it to just change the bearing for them? Can you even get the whole assembly? The parts store just lists one assembly for it. I don't get it what gives. Also i am changing the following parts while i do this.
plugs
plug wires
timing belt
drive belt
tensioner
idlers
thermostat,gasket
distributors
rotors
waterpump
as far as spark plugs go i've never messed with this type of vehicle do i need these little plug seals i've never heard anyone mention them but i see them listed as i said i need to get a service manual
if there are any other parts that anyone could suggest to change when i do this project let me know cause the only other teardowns i will do on this 200,00 mile car is a rack and pinion rebuild and change motormounts at same time and then uca bushings
It sounds like you have a good game plan; I'd just add the cam and crank seals to the list (not a question of if they leak but when! lol). ;)
The two idlers are different... http://www.trademotion.com/partlocator/ind...=19&catalogid=1
I would be suprised if you could find just the bearing; Lexus still makes evey nut and bolt that goes on your car! ;;)
yeah i've been trying to plan it out before i buy into it all. the car was free so i can't complain. i am just really trying to figure out what i need to replace or rebuild the idlers. hopefully it will all fall into place pretty well. i love that car!!! :unsure:
thanks a for the info much appreciated, and i'll add that to my parts list
hey check this out and tell me what you think blake
bearings
Those look like the right parts, but I don't know...they aren't that much cheaper than the OEM parts (Park Place offers free shipping and no sales tax too!). "Cheap" doesn't do me justice, but I'd splurge on the real Lexus parts for the timing belt componets. Having changed the timing belt in my 95, I'd be uncomfortable using generic brands especially since it takes such a long time to do (6-8 hours probably).
:cheers:
:cheers:
and roger i understand why.....by the way you got any site i can pull down specific specs on motor ie. compresion, stroke x bore, valve sizes, cam grinds etc? oh yeah i can't really tell on the exploded view which two seals you are talking about specifically, could you show me more please if it's not too much trouble. Thanks for your time sir.
Sapper, I circled what I think are the cam and crank seals in the exploded view (someone please correct me if I'm wrong). post-1461-1136420366_thumb.jpg
Here are some pictures from WandaW:
http://us.lexusownersclub.com/forums/index...topic=19816&hl=
Hey blake....let's see that picture behind the data in your posting!! I spy one hell of a good looking LS400! ;)
sweet thanks for the pic. about the cams i was looking at that break down. is there only one cam seal, strange i know there is more than one cam but why only one seal. i'm gonna take a closer look
The picture is wrong. ;) There are 2 cam seals. I know both of the guys that do most of the work for that site pretty well because I email them so often about parts that are missing, wrong, etc.! They have cheap OEM parts, free freight, and no sales tax, so I always come back!
hi there
i recently did the whole timng belt job myself, and would also recommend you do the ACCESSORY belt tensioner pulley brg and idler brg. These were quite worn and squeaky. I know you dont have to go all the way in to the engine to do them later,but hey why do anything twice? bought them from lexus and then a mechanic friend said the brg was a very common one on taxis, and he pressed them in to the old pulleys for me $15 each, so I took the lex ones back and got my $100 each back.
The toyota soarer site in Aus mentioned the timing belt idler brg and tensioner brg could be matched at a brg specialist and pressed in for much less than the oem part cost. Down load all your instructions from lexls.com and lextreme.com.
cheers
almost forgot,
yes- 2 cam seals, one crank seal.
Imagine if they start leaking, you got to go in again and do it all over.
my email is cullen.stagg@us.army.mil lemme know what you got as far as part numbers
I don't know if the parts for 1994 are any different than 1991. But here are the part number for 1991 LS400:
Timing belt tensioner 13540-50022 ~ $39.37
Idler pulley no.1 13505-50022 ~ $98.00
Idler pulley no.2 13503-0F010 ~ $63.00
Crank seal 90311-A0001 ~ $7.00
Camm seal 90311-38036 ~ $5.55/ea. (You'd need two cam seals)
I bought my parts from www.irontoad.com
You can send them a request for parts. They will quote with part number for your specific vehicle.
Hope this helps.
You might want to look at www.autohausaz.com for common parts like timing belt idler and tensioner bearings as they are the OEM make (Koyo or NSK) bearings but they are much cheaper then anywhere else(FYI, I have no affiliation with this site). However, the water pump and timing belt I would only buy from the dealer as these to me are critical components and you don't want to risk buying a timing belt that's been sitting on a shelf for two years. Also, another site I like is www.drivewire.com. Like Swordfish noted, you most likely could use new bearings for the accessory belt idler and tensioner pulley and you might also carefully inspect the condition of the bearing for the clutch fan mount bracket.
