1993 300 Radio Dead
yahbutt
car?
exactly!! Are we talking an ES, IS, GS, SC, RX??? which model 300?
if you actually took the unit out or disconnected it, there may be an audio system security code that may need to be punched in for the unit to work again.
steviej
Group: Members
Car Model:1993 300
You cut a wire, or have un-grounded the thing, or blow a fuse, or shorted the player out.
Now you're left with not *trying* to take it out, you have to take it out. COme on it's not hard. Pop the bottom trim off. Pull the vent out - easier to do it by taking the blove box out & pushing it foreward, then unscrew your 4 machine screws...
Not else holding it in but 3 connections to the radio stuff, the clock & the A/C controls.
