Seafoam Air Intake Cleaning
artbuc
My 99 RX is approaching 60k miles and I want to clean air intake with Seafoam as has been recommended on this message board. The instructions on the can give a couple of ways to add. Is there a best way to add Seafoam on the RX? If so, what is it?
I was thinking of doing this: removing air supply boot from throttle body, putting the Seafoam in a spray bottle and spraying it right into the throttle body. This seems like a btter way than just pouring it into a vacuum line.
The engine will not run if the maf is disconnected from the air intake
SK, where and how should I add the Seafoam? Seafoam suggests pouring it slowly into a vacuum line such as the brake booster line. I can do this but I wondered if there is a best way to do this on the RX. Maybe it really doesn't matter how I do it as long as I follow the basic instructions on the can?
If something isn't broken why insist on fixing it...??
Unless you have been using an intake air filter not OEM or equivalent, say K&N, in which case I fully understand.
Edited by wwest
