Texas LS400 Posted November 19, 2005 Share Posted November 19, 2005 Hi all, My brake lights will not work. I checked all 6 bulbs(2 left, 2 right and 2 center) they were all fine and the fuses under the dash were fine. The tail lights work when headlights are turned on but when you push the break pedal, the tail lights don't change. I checked the wiring going to each and it is fine. Is there a fuseable link in the engine compartment that might be the culprit? If not, what other things can I check. There is no warning on the dash coming on either. Thanks for your help. Quote Link to comment Share on other sites More sharing options...
dcfish Posted November 19, 2005 Share Posted November 19, 2005 Hi all,My brake lights will not work. I checked all 6 bulbs(2 left, 2 right and 2 center) they were all fine and the fuses under the dash were fine. The tail lights work when headlights are turned on but when you push the break pedal, the tail lights don't change. I checked the wiring going to each and it is fine. Is there a fuseable link in the engine compartment that might be the culprit? If not, what other things can I check. There is no warning on the dash coming on either. Thanks for your help. ← There is a thread about a trunk hinge wiring problem with early LS's, If I recall the wiring from the factory is too short and wears the coating off and shorts out causing a plethera of problems. Search and ye shall find http://us.lexusownersclub.com/forums/index.php?act=Search&f= Quote Link to comment Share on other sites More sharing options...
alsalih Posted November 19, 2005 Share Posted November 19, 2005 Sounds like a bad brake light switch, located behind the brake pedal. It's a simple contact switch which triggers the brake lights once the pedal is pushed. Quote Link to comment Share on other sites More sharing options...
Texas LS400 Posted December 16, 2005 Author Share Posted December 16, 2005 Sounds like a bad brake light switch, located behind the brake pedal. It's a simple contact switch which triggers the brake lights once the pedal is pushed. That is exactly what it was. Bought the stop light switch for the pedal at CarQuest. Thanks for helping out. Quote Link to comment Share on other sites More sharing options...
alsalih Posted December 17, 2005 Share Posted December 17, 2005 Glad to hear that, and thanks a bunch for the update I've noticed too many times that people will not follow up after they fixed something leaving us all in the dark! Quote Link to comment Share on other sites More sharing options...
