! have a 96 es300 with 96,000 on it .I have some of the more common problems i've seen on other posts. they are helpful for ths new guy . but i have this loud wind noise coming from the side windows. is there a trick or easy fix with the seals . they seem fine. no cuts or wear that i can see. does any one have an idea?
I have read that closing the doors by pushing on the windows instead of the door will cause this. The windows should be re-aligned. You could probably do it yourself depending on how into that you are.
