I WAS PLANNING ON CHANGING ALL 4 SHOCKS FOR THE CAR. THE PRICE IS $395 NOT INSTALLED FOR ALL 4. I KNOW TRD HAS THESE ITEMS TOO, BUT COST ALITTLE MORE. HAS ANYBODY EVER GOT THESE DONE BEFORE AND THE DIFFERENCE BETWEEN THEM, OR THE DIFFERENCE BETWEEN STOCK AND KYB? THANKS FOR YOUR HELP.
I cannot say on quality of the model you are getting but I believe the L-Tuned shocks were KYB. If they are good enough for Toyota/Lexus/TRD to use and rebrand, it should be pretty good. In the end, it is still only an educated guess by me :) so hopefully someone with direct experience will reply.
I cannot say on quality of the model you are getting but I believe the L-Tuned shocks were KYB.  If they are good enough for Toyota/Lexus/TRD to use and rebrand, it should be pretty good.  In the end, it is still only an educated guess by me :) so hopefully someone with direct esperience will reply.
Thank you for your reply
Kyb makes most toyota shocks and i would also say the trd ones are as well since they are usually eibach springs and kyb shocks.
Thanks for the reply, I just got the KYB ones today and they do feel better than stock.
Glad everything worked out for you. :cheers:
