Nesby Posted October 24, 2005 Share Posted October 24, 2005 Hello, My driver's side low-beam headlight is out. I replaced the bulb and the fuse (even though not blown), but no luck. Any ideas on what else this could be? Thx for any help you can provide. -Brian Quote Link to comment Share on other sites More sharing options...
Nesby Posted November 4, 2005 Author Share Posted November 4, 2005 Please help!! :cries: Hello,My driver's side low-beam headlight is out. I replaced the bulb and the fuse (even though not blown), but no luck. Any ideas on what else this could be? Thx for any help you can provide. -Brian ← Quote Link to comment Share on other sites More sharing options...
lsrxlex Posted November 5, 2005 Share Posted November 5, 2005 I have a 1990 RX300 too, but I've never had problem with headlight. So I don't know how to help except to say that I'd trace the wires and check the voltage using a voltmeter. I have a set of 1999 Lexus RX300 shop manual, so if you need any page/chapter I can take picture and send it to you. Just tried to help. Good luck. Quote Link to comment Share on other sites More sharing options...
Nesby Posted December 8, 2005 Author Share Posted December 8, 2005 It turns out that when I turn the foglights on, both headlights light up! But when I just turn the headlights on by themselves, the left one is out. Does this make sense to anyone? Quote Link to comment Share on other sites More sharing options...
liqrsicc Posted December 8, 2005 Share Posted December 8, 2005 It turns out that when I turn the foglights on, both headlights light up! But when I just turn the headlights on by themselves, the left one is out. Does this make sense to anyone? ← you sure its not the bulbs? i had a similar problem with my taillights. when i turned my lights on the left taillight wouldn't work. but when i stepped on the brake, both worked. i just changed the bulbs and it fixed everything. and if its not the bulbs or the fuse then it just might be the wires Quote Link to comment Share on other sites More sharing options...
cnynctry Posted December 10, 2005 Share Posted December 10, 2005 Hello,My driver's side low-beam headlight is out. I replaced the bulb and the fuse (even though not blown), but no luck. Any ideas on what else this could be? Thx for any help you can provide. -Brian ← Might be one of the relays is not making good contact. I has something like your problem with the daylite driving lights. tapping on the several relays in the front near the radiator cleared it up and hasn't returned. At least it's cheep to try. Quote Link to comment Share on other sites More sharing options...
JONXDOE Posted November 26, 2006 Share Posted November 26, 2006 Hello, My driver's side low-beam headlight is out. I replaced the bulb and the fuse (even though not blown), but no luck. Any ideas on what else this could be? Thx for any help you can provide. -Brian hey brain, im new here so bare with me. i have a 99 rx300 and i have aftermarket HID. BY phillips. one day the ballast went out and when i got a new one, installed it but everytime i turn on the headlight the fuse would keep poping. few days after try to work on it again the left side headlight wont work. there power going tot he wire but doesnt work any ideas? Quote Link to comment Share on other sites More sharing options...
