Was just wondering if anyone has an issue like mine. Whenever I step on the gas from a stop my car doesn't respond right away, causing a hesitiation. It almost appears like the throttle has a dead spot...
i kind of have the same problem. and my friend also had a similar problem in his 2001 GS. he reset the ECU by disconnecting the battery cable for about 15 minutes. supposedly this is supposed to reset the computer and relearn your driving style. i'm going to try it on my 2006 gs this weekend.
After your search you'll know but all Lexus built after 1998 or so do this, its a side effect of the throttle by wire system.
Yep.
