Driver Door Lockout
I'm having a bit of a door crisis with my 92' ES 300. The driver door won't open from the inside or outside. Essentially it's shut and staying that way. I figured it was the rod clip witch I had had to replace on the passenger side not too long ago. I unfortunately found out this wasn't the case only after I aggressivly opened the door panel (wich is not easy on a shut door!) - All of the handle rods, lock rods, and clips are in place and functioning. It's the latch that actually holds the door closed that seems to be the problem.
So here's where I'm at: moderate intereior damage, door still shut, at the end of my rope. If anyone has an idea to what the problem is, knows where I can get a door schematic, a latch diagram - or even a way to bypass the system and open the door so I can remove/replace the latch - I would greatly appreciate any help!
