PHML Posted October 3, 2005 Share Posted October 3, 2005 Guys, Need your help. The noise occurs only when tuning ignition to ON position and at startup....no matter if the a/c is ON or OFF.....last about a minute....driving me nuts. Any ideas? Thanks in advance. Video: Blend Door / Servo Motor??? Quote Link to comment Share on other sites More sharing options...
vsdhillon Posted July 20, 2006 Share Posted July 20, 2006 I'm having the exact same issue on my GS300 and was quoted a price of well over $1000 to replace the air mix and 2 servo motors under the middle of the dashboard area. Was told they need to special order the part. Keep in mind I got that quote from the stealership. If anyone has a better and cheaper way to fix this problem, I'm open to suggestions. Thanks. Guys, Need your help. The noise occurs only when tuning ignition to ON position and at startup....no matter if the a/c is ON or OFF.....last about a minute....driving me nuts. Any ideas? Thanks in advance. Video: Blend Door / Servo Motor??? Quote Link to comment Share on other sites More sharing options...
PHML Posted July 31, 2008 Author Share Posted July 31, 2008 I'm having the exact same issue on my GS300 and was quoted a price of well over $1000 to replace the air mix and 2 servo motors under the middle of the dashboard area. Was told they need to special order the part. Keep in mind I got that quote from the stealership. If anyone has a better and cheaper way to fix this problem, I'm open to suggestions. Thanks. Guys, Need your help. The noise occurs only when tuning ignition to ON position and at startup....no matter if the a/c is ON or OFF.....last about a minute....driving me nuts. Any ideas? Thanks in advance. Video: Blend Door / Servo Motor??? Anyone fixed this A/C Noise problem yet? Post up ppl!! Quote Link to comment Share on other sites More sharing options...
