dwells50 Posted July 15, 2003 Share Posted July 15, 2003 Hi! My 1997 LX450, with 100K mi., has a bouncy ride in some road and wind conditions. If I give it the old "shock test" in the driveway, by pushing down the bumpers, the shocks seem good. I have heard that, when purchased new, the Lexus dealers would replace the shocks and springs with stiffer Landcruiser parts if the owner wished. We don't wan't to lose it's comfortable smooth ride, but the bounce really feels dangerous sometimes. Can I get good results just by replacing with firmer shocks, if so, whats a good choice? Thanks, Drew Quote Link to comment Share on other sites More sharing options...
ellieoh Posted July 29, 2003 Share Posted July 29, 2003 Shock absorber selection is related to your vehicle use, if you are mainly a highway user then you have a couple of options - (1) stay with the factory standard issue shocks and springs - (2) You may want to consider upgrading to OME (Old Man Emu) shocks & springs, they originate from Australia and come in many different heights and ride options. In my humble opinion a big improvement on original equipment. Regards David 1998 LX450 1997 Landcruiser Quote Link to comment Share on other sites More sharing options...
MWD Posted August 15, 2003 Share Posted August 15, 2003 ellieoh: Have you tried OME shocks and springs? On which vehicle? How were they better? I have a 97 LX450 with 75,000 miles and am thinking it may be time for new shocks. Testing the shocks by rocking it side to side I find that it takes a couple of oscillations for the movement to die down. Other than that, it seems OK. Thanks, Mike 97 LX450 81 Landcruiser FJ60 Quote Link to comment Share on other sites More sharing options...
ellieoh Posted August 15, 2003 Share Posted August 15, 2003 I have OME shock & springs on my 98 LX470, the results are a huge improvement on the standard setup. Try - http://sleeoffroad.com for advice and they are a source for OME suspension which comes in many different combinations. Good luck David Quote Link to comment Share on other sites More sharing options...
dougjohn Posted August 26, 2003 Share Posted August 26, 2003 I have OME shocks and springs on my LX 450 as well. But before going with OME, you need to know that there will be a huge difference in ride. If you like the floaty feeling of the factory Lexus shocks and springs, you may not like the OMEs. If you don't like the side-to-side swaying and the bounciness that you described, either Land Cruiser or OME may be the way you want to go. You just need to decide what it is you want. For what it's worth, since switching to OME from stock, I've been very happy with the ride and performance. It is a stiffer ride, but much more controllable. Good luck. Doug Quote Link to comment Share on other sites More sharing options...
