I have 93 ES300 with a Pioneer Radio with CD. Originally the Radio worked fine, but the CD player would not activate. The CD mag could not be ejected. So I disconnected the connector and performed the connector tests as per the factory manual.
This process entails disconnecting the Radio - CD connector at the CD part and testing the output from the radio.
Well, I must have done this wrong because the Radio is now dead. The car fuses are fine. I had a spare Pioneer radio (without CD) and installed it. All works fine.
Looking at the Radio unit, there is no external fuse showing.
So is there an internal fuse?
Could use the schematics if someone has them. :cries:
Cheers
DaveH
Could use the schematics if someone has them.:cries:
Cheers
DaveH
yes there are 3 fuses on the pcb board at the radio connctor. they are marked 6.3v so not hard to find. new 6 volt fuses can be soldered in.
Thanks PIONEERSUBY
Disassembled the unit, could not locate the fuses.
On the boards, CNP 2270,2994, 2340, 2388 could only find fuses labelled FU401 and FU402 on assembly CNP2994.
Appreciate further assistance,
thanks in advance.
DaveH
Thanks PIONEERSUBY
thanks in advance.
DaveH
yes thats them i belive does it say 6.3v on them.
They say 6.3 A.
One tested to be opened.
Finding a source for parts is proving very difficult, can you assist?
Thanks in advance
DaveH
They say 6.3 A.
Thanks in advance
DaveH
email me at pioneersuby at woh.rr.com with your info and i can send you the fuse
Edited by SKperformance
Just a note when adding an email adress to any thread never use it in the exact form unless you like spam emails.
I edited yours
  • 3 months later...
They say 6.3 A.
Thanks in advance
DaveH
did you ever fix your problem I did the same thing and would like some tips if you have any?
thanks
  • 2 months later...
I don't know if the message I sent yesterday got to you.
If it did then this is just a repeat.
I'll take you up on you offer if it is still on the table.
Would like two if possible, will re-imburse.
I have two radios that do not work. Quite willing to send you one of them.
Dave Honkanen
2878 Grandeur Ave
Ottawa Ontario
K2B 6Z1
honkand@navcanada.ca
NOTE: To SKperformance - please don't edit this ......
