Rx-300 Drl Stoped Working
cnynctry
2001 Rx-300 daytime running lights (DRL) decided to stop working. Hight beams worked fine and parking brake is off. At first I thought it might be the switch in the parking brake since I hardly ever use it. While checking the #1 fuse (which was fine) I decided to tap on the relays in the same box and the DRL's decided to start working again. I pulled all three relays and cleaned the contacts and put them back in. DRL's have been working fine since. I'm not sure exactly which relay was stuck, but it's something else to try before you take it to the dealer if you are having the same problem.
