Replace Coolant And Flush
rexlex
How do you flush the cooling system?
Where are the block drain plugs?
How much is in the block if I just drain and fill?
How do you drain it?
Should I use pink or red?
Full strength or 50/50?
How much should I buy?
How much does it hold?
Should I replace the thermostat?
Thanks
What is your experience level in automotive maintenance and repairs?
All quantities are listed in the owners manual at the back of it.
I have done flushing and just drain and fill in many of my american cars.
Also changed the plugs in my RX but dont have a repair manual for locating some things as others are common sense. Some capacities are not always the same as the manual. Usually do all my own maintenance and repairs except tire replacement, tranny flush, and some timing belts.
