WtaggiN Posted August 27, 2005 Share Posted August 27, 2005 I recently got an aftermarket head unit installed in my 94 ES300. It works find, everything sounds good, but for some reason my turn signals and hazards no longer work. I was thinking it was a fuse....I looked at the TRN 15 fuse in the drivers side panel, but it wasn't blown. Is there another fuse or any other problem that could be causing these not to work? Quote Link to comment Share on other sites More sharing options...
Toysrme Posted August 27, 2005 Share Posted August 27, 2005 Yes, the 10 amp haz fuse. Quote Link to comment Share on other sites More sharing options...
Bigrick Posted August 27, 2005 Share Posted August 27, 2005 I had the same problem when I changed the display on my '97. I forgot to plug the 4-way hazard switch back in. Quote Link to comment Share on other sites More sharing options...
WtaggiN Posted August 27, 2005 Author Share Posted August 27, 2005 Where is the 4 way hazard switch? Quote Link to comment Share on other sites More sharing options...
Bigrick Posted August 28, 2005 Share Posted August 28, 2005 On my '97, it is above the radio. The wires plug into the back of the part of the dash removed to access the radio Quote Link to comment Share on other sites More sharing options...
SKperformance Posted August 28, 2005 Share Posted August 28, 2005 I think the hazard harness was not reconnected when the climate control was installed again with the radio. Quote Link to comment Share on other sites More sharing options...
WtaggiN Posted August 28, 2005 Author Share Posted August 28, 2005 I think the hazard harness was not reconnected when the climate control was installed again with the radio. ← So it is pretty much just one of the plugs that connects to the air conditioning part? Quote Link to comment Share on other sites More sharing options...
SKperformance Posted August 28, 2005 Share Posted August 28, 2005 Sort of , it is a plug right behind the hazard button. Quote Link to comment Share on other sites More sharing options...
jtf Posted December 26, 2010 Share Posted December 26, 2010 how do you change a turn signal switch on a 1997 es300 lexus Quote Link to comment Share on other sites More sharing options...
