OK I have replaced the dogbone and will attempt to replace also the front mount.
I searched a lot of forums and discovered that I shall need a 17 mm socket and need to jack up the oil pan.
Out of the three bolts one has to be removed from underneath and two from the top.
Do I need to put the car on a ramp , remove the bolt from underneath first , then put the car back on level, place a jack under the oil pan and remove the other two?.
(Oh I forgot that I should remove the center bolt as well)
Is there any tip in doing this? What is the torque specification?
Are the bolts hard to break loose?
appreciate any help
Thanks
What year of ES300?  If it is 93 model then I can pass on the repair manual procedure.
DaveH
Yes it is a 93 es300 v6
appreciate repair manual procedure
I wish that you also have the procedure to remove the front exhaust pipe
Thnaks
  • 6 months later...
DaveH
I am about to do this this weekend, could you please pass th erepair manual to me ? email is luis@mds-corp.com
thanks !!
