PES300 Posted August 17, 2005 Posted August 17, 2005 I did a can of seafoam and the performance of the car has improved a lot. It also runs quieter too. But does it actually removes or cures sludge problem?
SKperformance Posted August 17, 2005 Posted August 17, 2005 Where did you find seafoam in Ontario? Seam foam is a good diy fix it is not as good as a motorvac as it uses alchole and methanol which evaporate too quickly to deeply and effictivly clean thick carbon deposits.It does help break them down very well for an store shelf product.
PES300 Posted August 17, 2005 Author Posted August 17, 2005 In Ontario u can buy seafoam at car quest 560 Dennison for around CAD 14 or in a shop near HW7 and Kennedy for 11.50
Toysrme Posted August 17, 2005 Posted August 17, 2005 Amazing what shipping does. Only costs $5 a can down here. Seafoam will dissolve a lot of oily things, other's it'll loosen it up enough so it's picked up in the oil like it should have been in the first place What? SK you're way off base. Seafoam is: 40-60% Pale Oil 25-30% Naphtha 10-20% IPA (isophthalic acid) Trans-tune is the opposite. Methyl (Methanol) It eats aluminum like crazy! It also has a bad tenancy to gel oils if left in contact for a few weeks. Only complete idiots, or people with enough money to constantly rebuild an aluminum engine use it for anything.
