Hello,
Does anybody know how many years the CV joint boot will last?
Everytime I change the oil, I always check and look at it and it looks good, but i never know when to change it.
Any ideas?
Thanks,
If it is oem about 5-7 years
after market 3-4
Way too many variables for it to degrade though.
Heat cold
average temps
turns and so on.
Thank you SK
This one has original from '97.
Should I go head and change it or wait?
How much it will cost?
Thanks,
If the boot is recently ripped or cracked and no bearing play can be found then you only need to replace the boot not the whole axle.
Get the OEM boot kit from toyota ,it is only about $70
And if it's the whole assembly? :unsure:
:cheers:
