Oil Filters For Rx 300
larrytrk
Does anyone know if there are any problems in using the toyota Highlander V6 oil filter # 90915-YZZB1 in an RX
which calls for a # 90915-YZZB9 ? $5.00 vs $15.00 bugs me if the filters are the same.
Thanks, Larry T
Thanks, Larry T
Here is an easy way of finding out. Go to your local parts store and look in a FRAM oil filter book. Look to see if the part number is the same for both models. That is the best way to answer your question. :D
fram makes crap filters and it is generic
they will list a part for as many cars as possible , just becaseu the threads and size are similar
that makes it easy to sell
that is a very bad way to compare the differences and advice
go to the dealer and ask them to see both filters look at the amount of holes around the main journal
and the size of the gasket
also the overall lenght of the filter for oil capacity
I just found out I can order the Lexus # in a 10 pack for about half price, from any Toyota dealer!
This can be quite a savings and I can stick to the Factory Filter!!
Thanks for your comments,
Larry T
Its clear that you do not see the point. The point was to see if it is the same part for both vehicles. Not to use the part. As far as fram it self. I do personaly use the filter on my two race vehicles and have no issue.....Generic, no. Aplication per car...
As stated a person can go to a dealer, but in most matter the parts guy won't be able to answer the question abou this type product. Dealership tech's and parts guys go by the part number that are stated by Lexus. Toyota part number are a whole other matter.
i guess we are both missing each others points
lol :D
the list as much as possible to fit with lots more tolerances
look in the fram book as i did yesterday
and it lists every lexus oil filter asthe exact saem part#
i am not sure as i don't change many other lexus oil filters but i don't think they list the same part from them
there are redundant #'s ,yes
just like the camry one is listed as the es one in the dealer
ut take a look at the dealer and compare the 2 's size if nothing else
the more expensive one may just be a bigger one which can hold more oil and has more filter media in it
just like a trick i learned at gm as a tech
there are other filters that fit dead on and have the same holes just with a longe area to filter for a few cents more
  • 3 weeks later...
