RedLexusSC400 Posted July 31, 2005 Posted July 31, 2005 Okay, I'm gonna sound stupid here... but I have a question about what would fit. I found wheels that are 18x8.5 offset 20 for the front and 18x9.5 offset 25 for the back, bolt pattern 5x114.3. I know the bolt pattern fits my 92 SC400, but I read that they have a stock offset of +50mm. And I'm not quite sure about what exactly the offset is. Would I have a problem with rubbing with the front tires at 245-40-18 and the back tires at 275-35-18? I'd really appriciate any info, and I want to order these tires today! Ha ha, I can never wait... Thanks! Bry
JIBBBY Posted July 31, 2005 Posted July 31, 2005 Okay, I'm gonna sound stupid here... but I have a question about what would fit. I found wheels that are 18x8.5 offset 20 for the front and 18x9.5 offset 25 for the back, bolt pattern 5x114.3. I know the bolt pattern fits my 92 SC400, but I read that they have a stock offset of +50mm. And I'm not quite sure about what exactly the offset is. Would I have a problem with rubbing with the front tires at 245-40-18 and the back tires at 275-35-18? I'd really appriciate any info, and I want to order these tires today! Ha ha, I can never wait...Thanks! Bry ← NO THAT WILL WORK FINE WITH YOUR STOCK SUSPENSION AND SPRINGS. THE REARS WILL SCRAP FIRST. I AM RUNNING THE SAME ON MY CAR AND I HAVE LOWERED IT ONE INCH.
thoffen Posted August 1, 2005 Posted August 1, 2005 Okay, I'm gonna sound stupid here... but I have a question about what would fit. I found wheels that are 18x8.5 offset 20 for the front and 18x9.5 offset 25 for the back, bolt pattern 5x114.3. I know the bolt pattern fits my 92 SC400, but I read that they have a stock offset of +50mm. And I'm not quite sure about what exactly the offset is. Would I have a problem with rubbing with the front tires at 245-40-18 and the back tires at 275-35-18? I'd really appriciate any info, and I want to order these tires today! Ha ha, I can never wait...Thanks! Bry ← You should try the wheel and tires forum. The short answer is that these wheels will not be a good idea without some modification. For SC300/400 models, don't go with less than +40 offset if you want to be safe.
