I did the Ac code pull & it came back code 24
The light stays solid for 3 sec then starts to blink when the ac is on.
The compressor is quite and it clicks on for 2 sec and then shuts off , it was ice cold just the other day
The vehicle is a 99 gs300
Any help would be great!
Thanks
Dan
Thanks
Dan
After a review of the compressor , the clutch appears that it needs to be replaced i can turn it by hand as i should be able to ?, but it has play back and forth and side to side + has grease pressing out from the front ,
My Webpage
I found this to help with the replacement of the ac clutch. Can anyone confirm that you can change the ac clutch on the vehicle? , & not have to release the freon?
Also the best place to find a replacement ac clutch at a bargain, I don't know if you have any dealers that give discounts on this site the anyone could refer me to.
Thanks
Dan
  • 2 years later...
Thanks
Dan
<{POST_SNAPBACK}>
I know this post was a few years ago but I am having the same problem you are having. Did you changed the compressor and did it solve your problem?
thanks
My Webpage
Thanks
Dan
I realize that this post was a few years but I am having the same problem you had. Did changing the clutch or compressor solve you problem?
Thanks;
Dwight
  • 10 years later...
