branshew Posted July 20, 2005 Share Posted July 20, 2005 Anyone have a recommendation for a low dust brake pad for a '93 LS400. The last set of pads that I had put on my ES would squeal constantly and I want to avoid that problem this time. Quote Link to comment Share on other sites More sharing options...
dcfish Posted July 20, 2005 Share Posted July 20, 2005 Anyone have a recommendation for a low dust brake pad for a '93 LS400.The last set of pads that I had put on my ES would squeal constantly and I want to avoid that problem this time. ← OEM is the way to go. Buy them at a discount lexus dealer. Quote Link to comment Share on other sites More sharing options...
nc211 Posted July 20, 2005 Share Posted July 20, 2005 branshew, i agree on the oem stuff. but last month I was in a pinch and had to get some semi-mettalic pads from autozone for the fronts. They were like $25 for the front set. I have no complaints at all with them. I think the guy who put them on however forgot to grease a couple areas as I now get the clunck noise from the pads when I go backwards, then forwards. The pads are shifting. There is a TSB about this, and I'm just gonna grease them myself in a few weeks. But, again, I used autozone semi-metalic and have no complaints whatsoever. Quote Link to comment Share on other sites More sharing options...
branshew Posted July 20, 2005 Author Share Posted July 20, 2005 I figured OEM would be the way to go. Will I need to/should I replace my wear indicator sensors as well? Quote Link to comment Share on other sites More sharing options...
dcfish Posted July 20, 2005 Share Posted July 20, 2005 I figured OEM would be the way to go. Will I need to/should I replace my wear indicator sensors as well? ← That will be determined at time of inspection. Quote Link to comment Share on other sites More sharing options...
blake918 Posted July 20, 2005 Share Posted July 20, 2005 I figured OEM would be the way to go. Will I need to/should I replace my wear indicator sensors as well? ← You don't need to change the indicator sensors unless your brake wear light is on. I've had (and continue to have) great luck with OE pads. They're something like $50 at irontoad.com and be sure to lube up that shim on the back of the pad. Quote Link to comment Share on other sites More sharing options...
