Hard Time Starting
On occasion my 1998 GS300 will not start up right away. I have to keep the starter engaged for about 30seconds then the car will finally start. It fells like its getting no spark or fuel. Once it starts it runs fine. This seems to happen when I fill up the car with gas or when its low on gas (1/4 tank or less). Is there any sensors or relays that I should look at?
if the car is turning over i am not sure it might be a charging system problem at all more than likely it is the fuel pump pressure
when you turn the key forward and listen carfully before the key is turned to start
so you hear the whrrr of the fuel pump?
also if it doesn't start right away
try just turning the key forward to the on ,not start position a few times and leaving it in position a couple of secs and see if it helps
if so then it is a delivery of fuel problem
probably the pump but maybe the filter
but
reading it again you mention it is after refueling
possible over filling of the gas tank
loss of vacum pressure
try the fuel pump first
