namlexus Posted July 11, 2005 Share Posted July 11, 2005 i have lx470 2001 - By mistake i took the key out from ACC location at the ignition(Lock - ACC - start). Now i am not able to turn the key in either direction as if it is jammed at the location. it seems as if some anti-theft system got turned on. nothing is working - also tried moving the steering back and forth - All i can do is just insert key in and out. Thanks for the help. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted July 11, 2005 Share Posted July 11, 2005 the tumbler is screwed. I think someone else had the problem on another car and had to get a locksmith. you could try lubing the cylinder with the key in to loosesn the dirt holding the tumblers. Quote Link to comment Share on other sites More sharing options...
