nichola1 Posted July 8, 2005 Share Posted July 8, 2005 I blown the #9 (15 amp fuse) that controls the tail lights. After replacement the lights work but the tail light dash warning light stays lit. This happened after I stepped on the brakes. So I took the fuse out again, inspected for damage and put back in place. Started the car and the tail light dash warning light was now out. turned on my headlights and checked to see if any lights are out. All lights work, got back in my car and stepped on the brakes again and the dash light went on again, but did not blow a fuse and the lights work just fine, also the SRS airbag light is now lit. I replaced the fuse but light remains lit. Any suggestions would be helpful..... Quote Link to comment Share on other sites More sharing options...
lovlex Posted July 10, 2005 Share Posted July 10, 2005 did you check the license plate bulb? Quote Link to comment Share on other sites More sharing options...
