My driver side rear break light is out. I believe there are two bulbs and the one at the bottom left as you are facing the rear of the car is the one that is out. I opened the trunk un-snapped the plastic piece and peeled back the carpet. However, for the life of me I cannot figure out which nuts I needs to remove to gain access to the bulb. Does someone have a diagram that would help me? If not, I would greatly appreciate an explaination to how many of these nuts need to be removed and any other details. Thanks much.
No diagram, but I changed every bulb in my tails a few months back.
I remember there being 4-6 10mm nuts you must remove.
When you get those off, just pop the entire light assembly out.
Thanks much. When I get the 4-6 nuts off, does the light assembly come out from inside the trunk or outside the car?
Ya, and you also need to get a 10mm socket that is extra long for a couple of them if I remember correctly.
