Sam McBirney Posted July 1, 2005 Share Posted July 1, 2005 I have a 92 ls400 with 100k miles. One day I went to drive it and it wouldn't go over 20 mph. I pulled over and it was idling very rough. I turned around for home and after the 5 min. drive it smelled very hot. At idle I smell a strong fuel smell as though it is running very rich. It starts fine though. Any suggestions? :( Quote Link to comment Share on other sites More sharing options...
sha4000 Posted July 1, 2005 Share Posted July 1, 2005 I have a 92 ls400 with 100k miles. One day I went to drive it and it wouldn't go over 20 mph. I pulled over and it was idling very rough. I turned around for home and after the 5 min. drive it smelled very hot. At idle I smell a strong fuel smell as though it is running very rich. It starts fine though. Any suggestions? :( ← you need to give a little more info my first thought would be that your tranny might be about to go check your fluid level and smell it to see if is burnt i had a similiar problem in a 91 from lack of proper maintenance but it went gradually after about a month to finally it wouldnt go above 20 have you noticed a difference in power leading up to this? your fuel regulator could also be leaking these are just a few guesses and you would have to check the car and give a little more info Quote Link to comment Share on other sites More sharing options...
nc211 Posted July 1, 2005 Share Posted July 1, 2005 Cataletic converter clog is my guess, especially since you're smelling fuel. I bet if you looked under the car, those puppies were glowing red. They might be on the way out, sorry man. Those aren't cheap. I'd do a search on the topic, it's been discussed quite a few times. Just run a key word on Cataletic converter. Question: Did your check engine light come on in the car? Quote Link to comment Share on other sites More sharing options...
sha4000 Posted July 1, 2005 Share Posted July 1, 2005 also good advice nc a blockage in the exhaust would create a loss in power but if he is also smelling fuel he should check his fuel lines for a leak let us know something Sam Quote Link to comment Share on other sites More sharing options...
johnls400 Posted August 15, 2005 Share Posted August 15, 2005 how did you fix the problem? i have that too? Quote Link to comment Share on other sites More sharing options...
