mrsel3 Posted June 30, 2005 Share Posted June 30, 2005 how can i adjust the headlight? One is pinting up and the other is pointing down. This is after the car was repaired so these are new headlights. how do i kick in the auto aim that it is suppose to have? thank you Quote Link to comment Share on other sites More sharing options...
amf1932 Posted June 30, 2005 Share Posted June 30, 2005 how can i adjust the headlight? One is pinting up and the other is pointing down. This is after the car was repaired so these are new headlights. how do i kick in the auto aim that it is suppose to have? thank you ← This is a job for Bay Ridge Lexus. :D Quote Link to comment Share on other sites More sharing options...
lexusk8 Posted June 30, 2005 Share Posted June 30, 2005 mrsel3, does your '02 ES have height and width adjusters for each headlamp? It might be noted in your owner's manual (just thumb through the index and see if "headlamp adjustment" or similar can be found). All ES prior to the 2002 model have the height and width adjustment capability for the headlamps (just need a wrench or Philips to do the job). Quote Link to comment Share on other sites More sharing options...
melhadri Posted June 30, 2005 Share Posted June 30, 2005 Where are the "headlight adjusters" located on a 98' ES300? Quote Link to comment Share on other sites More sharing options...
SW03ES Posted June 30, 2005 Share Posted June 30, 2005 They are adjustable, but I'd let a mechanic do it. The auto leveling should work automatically. Quote Link to comment Share on other sites More sharing options...
mrsel3 Posted July 6, 2005 Author Share Posted July 6, 2005 They are adjustable, but I'd let a mechanic do it. The auto leveling should work automatically. ← My mechanic was terrrified to touch them, this after he did all my brakes and replaced the strut mount. My whole front end was replaced due to a collision. How do i kick in the auto leveling? Also I looked up the adjustment, however it is confusing and hard to find the screw for adjustment. I called my local dealership (bay ridge lexus), they want $50 and the car for the whole day. Quote Link to comment Share on other sites More sharing options...
AxlxA Posted July 7, 2005 Share Posted July 7, 2005 Umm, on my 95 camry(dare i say it is similar to a lexus?) the vertical adjuster is a long screw that sticks up from the headlamp. It looks like it's a screw holding the light in but if u keep turning it, it wont budge. I was !Removed! this for a good 3 mins before i realize it was an adjuster, not a bolter. Quote Link to comment Share on other sites More sharing options...
