thdoan Posted June 28, 2005 Share Posted June 28, 2005 I have V1 radar detector mounted on the front windshield of my 04 RX330. The mounting suction cups leave circle marks on the windshield. I tried Windex, and other glass cleaner products but can not remove those marks. Any one has the same issue. And any one knows how to clean it? Thanks, Quote Link to comment Share on other sites More sharing options...
knmaynard Posted June 28, 2005 Share Posted June 28, 2005 I have V1 radar detector mounted on the front windshield of my 04 RX330. The mounting suction cups leave circle marks on the windshield. I tried Windex, and other glass cleaner products but can not remove those marks.Any one has the same issue. And any one knows how to clean it? Thanks, ← If Windex really doesn't get it, then a very mild glass rubbing compound will. I have a guy that I buy all my Miracle Glaze products from that used some to rub out a scratch on my windshield, but he did it for free so I wouldn't have to buy the whole bottle for just that. If you have some other mild plastic or glass polish, use lightly and apply pressure as needed to clean it off. That's just my $.02. Good luck. Quote Link to comment Share on other sites More sharing options...
cantsleepnk Posted June 30, 2005 Share Posted June 30, 2005 I have V1 radar detector mounted on the front windshield of my 04 RX330. The mounting suction cups leave circle marks on the windshield. I tried Windex, and other glass cleaner products but can not remove those marks.Any one has the same issue. And any one knows how to clean it? Thanks, ← Try a Claybar with a diluted soap/water mixture as lubricant. Quote Link to comment Share on other sites More sharing options...
TOGWT Posted June 30, 2005 Share Posted June 30, 2005 The suction cups are made from vinyl and the suns heat causes (out-gassing) this is the plasticizer evaporating. A 1:1 solution (or stronger) of Isopropyl alcohol and distilled water will remove this residue. JonM Quote Link to comment Share on other sites More sharing options...
