Is300 Tires
heatherb328
I have a 2004 IS300 that I just purchased and I need to replace the tires. I've done some research, but I want some first hand advise from people w/the same car. I need a GOOD all-season tire (17" rims) that will get me through the spring, summer, and fall in New England. Any suggestions? Anything I should avoid? Any advise would be helpful.
When I bought my IS300, I got it with two sets of tires, high performance tires and all season tires. The all season tires were Dunlop Graspic 215/45R17 low profile tires. They worked pretty well in the snow. As far as how well they hold up, I couldn't tell you because I have only been through one winter with them. Hope that helps a little.
What is the exact tire size you need heather? Is it the 215 45 17 size? :unsure: Let me know & I will be better able to suggest specific tires.
:cheers:
The tire size is 215/45/17.
Based on what your looking for in a tire, I suggest these as the very best choices:
- Avon Tech M550 A/S
http://www.tirerack.com/tires/tires.jsp?ti...romCompare1=yes
- Yokohama Avid H4S
- Falken Ziex ZE-512
http://www.falkentire.com/tires_512.htm
- Toyo Proxes 4
http://www.toyo.com/tires/tire_lines/sport...r/proxes_4.html
- Pirelli PZero Nero
All are very good choices, the Avon & Falken are your best overall value & the Pirelli are the most expensive. I hope this helps & good luck! B)
:cheers:
