sonny4444 Posted June 15, 2005 Posted June 15, 2005 I have a '92 sc400. The overdrive button failed and wont stay in the engaged (overdrive on) position. Any ideas on a fix or replacement for this?...
SKperformance Posted June 16, 2005 Posted June 16, 2005 Are you sure it is the button and not the tranny? Otherwise remove the shifter and fix the button
sonny4444 Posted June 18, 2005 Author Posted June 18, 2005 It turned out to be a small piece of metal about the size and shape of a staple. Went to the junk yard and found an overdrive button assembly in a (Toyota) shifter. I took it apart and it had a staple that was missing on mine. (have no idea where the old one went, but it was small to begin with, so I suppose I’ll never find the 2 broken pieces) I swapped out the staple into the Lexus overdrive assembly, and it worked great.
steviej Posted June 19, 2005 Posted June 19, 2005 a DIY'er after my own heart. I love trompsing through junk yards to find simple parts. Good job. steviej
