I HAVE A 94 GS300 AND I NEED HELP ON HOW TO REMOVE THE HARMONIC BALENCER
well this is actually a section for instructions that are given but anyway... if you have the crank bolt off you need something like a gear puller. just go and buy a gear puller and you might need to put a socket in the place where the crank bolt used to be so that the gear puller can reach, and it should pull right off!
This topic is now closed to further replies.
