CAG Posted June 12, 2005 Posted June 12, 2005 I HAVE A 94 GS300 AND I NEED HELP ON HOW TO REMOVE THE HARMONIC BALENCER
jzz30 Posted June 14, 2005 Posted June 14, 2005 well this is actually a section for instructions that are given but anyway... if you have the crank bolt off you need something like a gear puller. just go and buy a gear puller and you might need to put a socket in the place where the crank bolt used to be so that the gear puller can reach, and it should pull right off!
SKperformance Posted June 15, 2005 Posted June 15, 2005 does anyone read the words search or what this section is?
