Win Lowe Posted June 5, 2005 Share Posted June 5, 2005 Lexus with 2JZ-GE engines (Sg 300, Is 300 Sc 300 are they Interference or not??? Yes and No. See below for information, this information came from a Gates web page I just rearrange them in this order. GS 300 1993-1997-2JZ GE Timing belt T215 change at 60,000 none Interference engine 1998-2004-2JZ GE Timing belt T215 change at 90,000 Interference engine IS 300 2001-2004-2JZ GE Timing belt T215 change at 90,000 Interference engine SC 300 1993-1997-2JZ GE Timing belt T215 change at 60,000 Interference engine 1998-2000-2JZ GE Timing belt T215 change at 90,000 none Interference engine Win Quote Link to comment Share on other sites More sharing options...
ColinBarber Posted June 6, 2005 Share Posted June 6, 2005 From what I understand the 2JZ series of engines are all non-interference. Quote Link to comment Share on other sites More sharing options...
Abear Posted June 9, 2005 Share Posted June 9, 2005 Whats the difference in Interface and non-interface? I'm still learnin. Quote Link to comment Share on other sites More sharing options...
TurboGS300 Posted June 9, 2005 Share Posted June 9, 2005 Whats the difference in Interface and non-interface? I'm still learnin. ← Jacob, It's interference and noninterference. Noninterference means if the timing belt breaks then the valves won't hit the pistion. Obviously interference is the opposite <_< Quote Link to comment Share on other sites More sharing options...
jskim9 Posted June 10, 2005 Share Posted June 10, 2005 Jacob, It's interference and noninterference. Noninterference means if the timing belt breaks then the valves won't hit the pistion. Obviously interference is the opposite <_< ← wait, if your timing belt breaks... how would that cause the valves to hit the piston? does it allow the valves to go out of timing? so for interference, even if the belt breaks, it won't cause the valve to hit the pistons? Quote Link to comment Share on other sites More sharing options...
ColinBarber Posted June 10, 2005 Share Posted June 10, 2005 The timing belt keeps the crank and cams in time with each other so yes if the belt breaks the valves go out of time with the pistons. Interference means the valves and pistons can touch each other and non-interference means they won't. Nearly every Toyota engine that uses a belt rather than a chain is non-interference. Quote Link to comment Share on other sites More sharing options...
