stever Posted June 1, 2005 Posted June 1, 2005 I have a question for those of you that are service savvy- I think the LS400 can be configured differently in terms of its security features. For instance, right now the doors do not automatically lock, however on other Toyotas I've owned the doors lock when the car starts up and unlock when the ignition is turned off. I would like to do similar things to the LS400 and customize it's operation but I am unsure how to go about it. Any advice?
1990LS400 Posted June 1, 2005 Posted June 1, 2005 If you use the search function of this forum you will find past topics about the autolock function not being a CBEST setting on the 98-00 LS. I can't remember if the auto-unlock function is available on a 98-00 but I would not want it anyway since it could be a safety/security issue.
GRAND_LS 4 Posted June 1, 2005 Posted June 1, 2005 Sorry, but No Auto-lock feature is on the 98-2000's.
stever Posted June 1, 2005 Author Posted June 1, 2005 If you use the search function of this forum you will find past topics about the autolock function not being a CBEST setting on the 98-00 LS. I can't remember if the auto-unlock function is available on a 98-00 but I would not want it anyway since it could be a safety/security issue. ← Thanks for the info. What is a CBEST setting?
stever Posted June 1, 2005 Author Posted June 1, 2005 If you use the search function of this forum you will find past topics about the autolock function not being a CBEST setting on the 98-00 LS. I can't remember if the auto-unlock function is available on a 98-00 but I would not want it anyway since it could be a safety/security issue. ← Thanks for the info. What is a CBEST setting? ← Sorry- I just did a search and read up some. So... what I gather is that the CBEST settings determine the behavior of the car and these can only be set at the dealership. Correct?
1990LS400 Posted June 1, 2005 Posted June 1, 2005 I probably used the wrong term - it may be "C-BES". Here is list of settings which I think are supposed to be for the 98-00 LS and which were sent to me by 99lsguy. C_BES_Codes.doc
1990LS400 Posted June 1, 2005 Posted June 1, 2005 The C-BES settings are set with a handheld device that the dealer (and probably repair shops) has. I would have to look at my repair manuals for information on what the devise is called.
stever Posted June 2, 2005 Author Posted June 2, 2005 The C-BES settings are set with a handheld device that the dealer (and probably repair shops) has. I would have to look at my repair manuals for information on what the devise is called. ← Thanks for your help. I know of a mechanic that may be able to change these codes. :)
