cfbugsbunny Posted May 18, 2005 Posted May 18, 2005 I took my 99 Lexus ES300 to a reputable tire dealer today and mentioned that my car pulls ever so slightly to the right. They did a front wheel alignment (what they call a thrust angle alignment) and said the toe was off a little and was then adjusted. They then went on to say the the only thing that can be adjusted on a Lexus ES300 is the toe and I may see a slight pull still. I think this is wrong and if the adjustment on the toe does not totally correct the problem then the issue is elsewhere. What can be adjusted on this year and is a Lexus dealer the only place that would have the correct tools to do this adjustment. Thanks :D
steviej Posted May 18, 2005 Posted May 18, 2005 your reputable tire dealer can be adjusted. Maybe they meant that the only aspect out of spec was your toe and that was all they could adjust??? Go to another one. steviej
lshen Posted June 17, 2005 Posted June 17, 2005 It could be a problem of the tires... your reputable tire dealer can be adjusted. Maybe they meant that the only aspect out of spec was your toe and that was all they could adjust??? Go to another one. steviej ←
