The car is an '01 ES300.
Is there a replacable filter in the trans pan or is it a washable screen?
If replacable, anybody know the Totota part number?
Thanks in advance !!!!!!!!!
:geek:
:geek:
It's a filter mesh screen. It's reusable so when you do a tranny flush (I suggest to replace the tranny gasket at the same time as a preventitive measure) all you need to do is clean it & re-install it again. B)
:cheers:
If i where you, i replace filter because that is hard to clean.
Part no: 35331-33031 cost $35.98
Good luck
Good luck
I disagree, why replace a perfectly good part with another one? If you can get it out of the tranny to clean it, surely you can clean it & re-install it? :blink: :whistles:
:cheers:
Good luck
:cheers:
It is cleanable, but for the $9 for the new gasket and $20 for a new filter/screen it is up to you.
Many thanks to everyone !!!!!!!
:D
Welcome! B) Let us know if the concern you have improves with the tranny maintenance.
:cheers:
