kyle0k Posted April 25, 2005 Posted April 25, 2005 i was gonna jsut ask SK but i decided woudl ask the rest of you too jsut in case you know from experience. http://rimsone.com/catalog/product_info.ph...products_id=209 ok i wanna get rims and i finally found good ones. I need to know,would these fit without problems? the only reason i ask is b\c its 18X8 i know alot of people have X7.5. Will i have problems? and also will i be able to still drop it an inch or no? thanks..
SKperformance Posted April 25, 2005 Posted April 25, 2005 like i mentinoed in the PM ,need to offsets to get an idea.
kyle0k Posted April 26, 2005 Author Posted April 26, 2005 for everyone wondering: well the tire size is the two avauilable choices i believe the 215\35 and the 225\40 hmm offset ill check.... ok the offset is 40 and the bolt pattern ican get in what i need 5 X114.3
SKperformance Posted April 28, 2005 Posted April 28, 2005 215 should fit ok but it is too small for a rim that wide to be done safely.
kyle0k Posted April 28, 2005 Author Posted April 28, 2005 ok so ure saying i shoudl be fine with minimal rubbing with a 1 inch drop and getting thse 18X8 rims?
SKperformance Posted April 29, 2005 Posted April 29, 2005 Grab a ruler and do some measuring if you want to know for sure. measure where the tire goes in the wheel well the stock rim width i think 15x6 the offset is 43 now add you new values to find your space taken up by the wider rims. 215 is not going to be a problem to mount but not to drive 225 may have rubbing issues under weight and lowered especially. The rim you want is commonly made by taiwan sellers under tons of names find another maker with the right offset and width
kyle0k Posted April 29, 2005 Author Posted April 29, 2005 hmm i mean ive looked and looked and i cant find any other rims that look like these
kyle0k Posted May 4, 2005 Author Posted May 4, 2005 ok does anyone know? i woudl do it myself and check but i have NO idea where to start or what to look at,i roughly know what each measurment means but im not positive.
kyle0k Posted May 4, 2005 Author Posted May 4, 2005 from my calculations i need to check if i have 1.882 inches of room, so thats like .941 inches of room to each side of the wheel\rim?
